The BOV also provides internet forums with hours and hours colourful discussion and debate...
Now here is my 2c...
In theory it also reduces the loss in turbine rpm during a gear change..This means when you get back on it, the turbine is at a higher rpm (because the compressor discharge hasn't been suddenly blocked) and therefore will spool up quicker...In practice though this may not be noticable much, if at all. It is also very hard to measure...
  • Replies 49
Posted Images
there the same you have on your car atm
Got pics?
I've been "window shopping" for some 4 pots.
:down:
BTW got my modified coilovers back from the engineers today. Going to fit the rear Ohlins coilovers tonight (and maybe the fronts if not too dark - bloody daylight savings!)
Block the BOV in and auto and you'll notice it easily.
Yeh i tried it(blocking BOV) went around the block......GHEY!!!
My theory is,if you got time to hear the psshhh .....your not changing gears fast enough....simple.
click on my signature;
Besides bullets are made from lead so they are soft as, you could shoot a turbine housing and youwn't even mark it :lol:
Mmmm... I shot a bullet through outer guard, inner guard, cast iron 308 block, inner guard once...I know it's no turbine housing :blink: but wtf are you talking about Willis ?
    • Oh please, when has anybody really been "done" when they say that? 😂
    • The part where you claim the car "is done" means you won't...
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
