Well push has come to shove
Have had a little bit of interest in my Cefiro...but no takers so I have bitten the bullet...bought myself a cheap Cima and now I have gotta get rid of everything possible on the Ceffy so........place your offers, nothing is sacred on this car apart from what will fit on my Cima and offers will not be refused unless profoundly obsurd!
email me at [email protected]
or if your after a speedy reply
[email protected](possiblity is might get blocked by spam filter)
if outside business hours(after 5:30pm) then call me on 041 994 6415 or 9242 3443
if anything is not listed just ask, Im sure I have spares of alot of stuff as I had a front cut aswell and stripped everthing possible off it so have a spare dash and components.
If you want picture of anything, just ask me
Enjoy the Massacre of a beautiful drift weapon!
Standard RB20DET
Rebuilt standard turbo
with loom and ecu
Timing belt recently replaced
$850
RB20 5 speed
$350
Lightened flywheel with 3 puck Brass Button clutch
$300
price for complete engine and G/Box $1300
red K&N Pod
$20
Front mount intercooler with custom 3" steel painted pipework(small amount needs to be replaced) and stainless steel T-Bolt hose clamps
$300
Oil cooler with sandwich plate(universal model so will fit others) to fit RB20
$150
Suspension
Front Strut tower brace
$100
Height adjustable suspension
Fronts: JIC coilovers
Rears: Racing Gear coilovers
$750 The lot
Hicas Lock Bar
$100
Dr. Drift Alloy Pineapples
$75
Interior
Aftermarket gauges include:
Greedy temp gauge mounted on A-Pillar
$100
Splitfire Oil pressure and Temp gauges in centre console
$50ea
Matching aftermarket steering wheel, handbrake cover, shift knob and floor mats
$100
RECARO(Millenium Edition) driver's seat
$800
unknown turbo timer(1-3 minute)
$20
Racing pedals
$10
BLACK Aluminium GT rear wing
$75
Indicators
$100 passenger side
$30 Drivers side (cracked and scuff mark)
Tail Light Centre Piece
$100
Wheels
UNKNOWN aftermarket 3 piece Rims
15x7.5inch front and back
some ridiculous offset(hang a good inch outside the guards)
Wrapped in Federal's 205 20% Tread
Perfect for AE86
$1000
AVS 16" rims
7.5" & 8"
wrapped in poor quality rubber
$400
Edited by SideWaysChef
https://www.sau.com.au/forums/topic/214408-ceffy-has-gotta-go/
Will get you a picture of the cage if you like....but engine is in car so cant really be bothered pulling it out for a picture.
Will work out a price for the aircon dash surround after the weekend mate. Can't remember what it looks like from memory...has been a long time since I sat in the drivers seat of it
Got a pic of the cage and the flywheel?
Also how much for the plastic that goes around the air con on the center of the dash
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
