i wouldn't bother with doing poncams it will eventually destroy your bottom end they are good for power but only if you are looking for big numbers and require taking the engine apart, also dont bother getting 1000cc injectors again only needed for big power aplications 250rwkw is a big number and very streetable and you would only need 550cc injectors for that and they sell for about 600 a set.
Have a look in the traders section for mechanical parts (dont buy them second hand your asking for trouble) and you should be able to pick up a profec b and power fc from someone pretty cheap just look around
My 2 cents :(
lucky its worth 2 cents, cams will not destroy your motor...
sorry guys i was going to do this myself so i asked my mate who is a mechanical engineer and has been working on engines his whole life and he advised me against it as he thinks they can eventually destroy the motor
EDIT
sorry guys miss i miss understood what he said, he said that it will destroy bottom end power not the bottom end whoops :D
Edited by WA_R32
this is what he meant
Cams won't destroy the bottom end of the engine, they will destroy the low end power. Its fairly complicated how it occurs. But basically a high lift camshaft will allow air a larger gap for air to get into the engine. This means that the velocity of the air entering the engine will be lower. If the velocity becomes too low, it reduces the turbulence of the airstream and the atomised fuel begins to condense into droplets. These droplets will lead to poor combustion as liquids don't burn. During combustion these fuel droplets are evaporated by the heat of combustion, all of the energy that goes into evaporating these droplets is no longer available for pushing the piston down. This is also why your fuel economy will get worse, as more fuel will need to be injected to get the same amount of easily ignited atomised fuel. However the aspect of a lumpy cam that has the greatest effect on low end power is the duration (how long the valves are held open for). There are a number of factors that cause this, but the easiest to explain, and probably the biggest contributor to a loss of low end power is the fact that a long duration camshaft will hold the inlet valve open longer. A long duration camshaft will hold the inlet valve open a considerable amount of time after bottom dead centre. At high rpm the inlet gasses are moving so fast that they have a considerable amount of momentum. Holding the inlet valve open past BDC takes advantage of this momentum allowing more air into the engine (air continues to flow into the engine even fter the piston has begun to travel upwards). However at low rpm the air has much less momentum, and consequently some air can actually be forced back out of the engine before the valve is shut. A similar thing occurs in the exhaust, except that the exhaust gasses are let out too
early. There is also the possibility of inlet gasses being sucked out the exhaust during the valve overlap period.
not confussing at all
Oh I see...
The thought of cams cracking the crank case seem utterly ludicrous... I was about to call greylands ffs....
But all is gud now! :P
Edited by Marco-R34GTT
  • 1 month later...
Blitz thunder bahaha
funds DID permit but now i've run into a bit of financial strife...
a few things can happen in the position i'm in at the moment...
car doesn't sell = cosmetic plans first... ie;
FULL URAS kit so that means new Front Bar, Side Skirts, Rear Bar WITH Vented Bonnet in black and boot in black... no wing and new rims...
then i'll move onto the FMIC and PowerFC and Fuel Pump...
Injectors and Turbo can come later...
i'll be doing the interior before i do the turbo and injectors...
if i DO sell then i have two options... ie;
buy my brothers TME... if he's sold that then i might have to go the Blitz 4 door Thunder and it WILL be manual turbo
i want the decals and all, man that car makes me melt
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
