Hi boys and girls, im looking to sell my Nissan Patrol.
Make: Nissan
Model: Patrol Short Wheel Base
mileage:Almost 300k
Transmission:4 Speed Manual
Colour: Yellow
Complied? Yes
RWC supplied? N/A
Currently registered? Yes till June
Price:$1700 AUD Ono.
Contact:PM or 0423734866
Comments / Modifications: She has: fire extinguisher, 2x spotlights, a home made centre console, massive sturdy roof rack, air horn (not working, i think its the ground wire), new LPG tank
Images:
Details of the car:
Well, to start off her name is Patty the patrol :rofl: (gf's idea). As you would expect there is a fair bit of rust but its not real major.
There is some on the passenger side a pillar, some on the passenger window sill and quite alot on the drivers door which has made the drivers door sag abit.
The motor is in great nick. She starts first time every time (literally...). Tyres on her are mismatched but have plenty of tread like 80%> easily, also comes with spare tyre with equal tread in the back.
The car recently had a new LPG tank fitted and is unbelievably good on Gas. She also runs on fuel but being a straight 6 the petrol disappears quickly.
Ive run the car on fuel at least once a week to lubricate the engine as gas runs hotter.
The car has a 4 speed gearbox and chugs along just fine.
The cars interior was molested once upon a time with fluff etc... that has all been ripped off and only the necessities have been left. The car has a massive bull bar with two "spotties" that work. Also included is a very sturdy roof rack. Interestingly enough the car has all its original papers, so you can peruse through all its previous owners. According to the papers it was originally from Noosa QLD lol, even regency inspection papers included lmao...
Also recently ive had all the oils and coolants replaced (gearbox oil, diff oil, engine oil, coolant, slave cylinder fluid, brake fluid) and a new battery also.
The car engine and mechanically wise is excellent. The body is a little rough no dents however, just rust and the original yellow has faded (expected for such an old car though)
Car also comes with a towball for towing the skyline =D Other than that the car runs excellent, awesome for a daily.
Reason for selling is that my skyrine is almost back on the road and i wont be needing it anymore.
If any questions arise please PM me or post, other than that i can be contacted on my phone anytime of the day and inspections are most welcome. Price is certaily negotiable.
*EDIT* Forgot to mention that the 4WD works also, low range highrange and all that.
Edited by jm4mp
https://www.sau.com.au/forums/topic/214487-sa-1982-nissan-patrol/
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
