Item:
Cefiro cross pipe
Unknown
Condition:
Very good
Price:
$60 + postage
To Fit: (What car)
RB20/RB25
Melbourne - south eastern suburbs
Contact:
PM or call/SMS 0416 623 381
Comments:
I am selling a CEFIRO RB20 cross pipe which is in perfect working order
Will bolt up to any RB20 and I'm assuming RB25 as the pipe design is the same
This pipe is perfect if you are looking at running no blow off valve - saves you blocking it off as the pipe has no port so you can take it off all together!
Item:
T4 dump pipe 3"
Unknown
Condition:
Perfect condition
Price:
$50 pickup
To Fit: (What car)
Any
Contact:
Comments:
Dump pipe came off an R33 and I was told it would suit my turbo but it didn't
Its in perfect working order, t4 flange so will suit most t4 turbos - larger flanged ones not the small flanged .63 rear housing
Item:
HCR32 standard intercooler pipe
125,000 km
Condition:
Perfect condition
Price:
$30 pickup
To Fit: (What car)
HCR32
Contact:
Comments:
Standard HCR32 intercooler pipe removed from my car
Not sure what size it is but it sits on the passenger guard/floor behind the head light
Item:
ECR33 arms
Unknown
Condition:
Perfect condition
Price:
$50 pickup
To Fit: (What car)
HCR32
Contact:
Comments:
These arms came with my ECR33 lower contol arms, not sure what they are or what they do, either way I don't need them
If you know what they are feel free to take them :D
If you have any questions feel free to ask
https://www.sau.com.au/forums/topic/214579-random-parts-clean-out/
Mate i'll take both the castor arms and the castor mounts (the ones you don't know what their for) if they fit an r32 GTST for $150 delivered to 2541 NSW. PM me back cheers mate
PM sent with details
i'll take the dump pipe pending it fits!
im in Ringwood,
the car isnt going at the moment but if your going past one day gimme a call on 0404 577 263
so we can do a test fitment.
i have cash here ready to go...
cheers,
Andrew
im in Ringwood,
cheers,
Andrew
Hey Andrew
Come down and pay for it and pick it up, if it doesn't fit then bring it back and I will refund you the amount
Thats the best I can do :blink:
Thanks
I am located in Hallam, south eastern suburbs of Melbourne
No worries, $80 for both pickup and I will refund the dump if it doesnt fit, provided I get it back in the same condition it was sold in
PM or call/SMS me if you want to arrange a time
Thanks :starwars:
im interested in the injectors if they didnt sell and maybe the stock intercooler pipe (you dont have the side mount cooler too?)
PM me!
Good old hijack
Sorry Abu
If you want a side mount i have 2 willing to sell one pm me an offer
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
