Make: Holden
Model: 1975 HJ kingswood red 308 v8
Milage: 178xxx
Transmission:3spd auto column
Colour: green white
RWC supplied? on request
Currently registered? yes
Price:3400 o.n.o
Contact:pm me
Comments / Modifications: unkownn cam, extractors,2.5 single exhuast, lowered, tachometer
This car has been a side project of mine for a while, got around to rwc/rego her and try to drive it to work once a week, the problem is its needs a good home to be love and restored, and i just have no room/$$$ to do that at the moment. The body is stright and rust free (besides lil bit of surface rust), it still has orginal paint work, interior is quite well also, with the owner doing a bucket seat conversion(modplated) but the door trims and rear seat are very good for a 30+ yr old car..
Just thought id throw it up here as i know theres a few carby bogan amidst.
https://www.sau.com.au/forums/topic/214744-1975-hj-kingswood-308/
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
