Hey guys, im having a real deliema, i just bought some of this Redline shockproof 80w140 the red stuff. Now i have chucked it in the diff and gearbox.
The problem im having is that it still feels like my gearbox is really tight. As in getting the gears in. Sometimes they feel like they are crunching to get in.
What do you recommend for gearbox??? or should i stick with this stuff?
Also I can really smell this stuff its really strong inside the car. is that normal??
Also its for my 34gtt. and i also have a short shifter.
Cheers.
sorry found right section;
Edited by R34ZOR
https://www.sau.com.au/forums/topic/214933-redline-shockproof-80w140/
80w140? This is similar to the Redline shockproof, is that what your using? Most people use lightweight shockproof.
I've seen MT-90 recommended although I'm going to try MTL first...
http://performancelub.com/Redline%20pricelist.htm
damn straight the short shifter will be making it worse.
but gearbox takes smurf blood. the human blood is for diffs not gearbox
although tecnically they are both gear oils...I would not be putting the red one esp. at the visc in the GB.
just oils with the appropiate friction modifiers. I use MT-90 redline...I found it better than shockproof as it too is really a gear oil.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
