Item:R33 Boost Sloenoid
Age:10-12 years
Condition: Good
Price: $25 posted anywhere
To Fit: R33, any Nissan with boost solenoid
Contact:PM here or 0438804282
Comments:
Brought this to make up a jaycar boost kit for my 32 but now looking at using the power fc kit.
Make up a Jaycar boost kit or replace your own boost solenoid
SOLD
https://www.sau.com.au/forums/topic/214939-r33-boost-solenoid-25-posted/
