RIGHT :D After fixing my fuel leak under ze car, i started it up, only to find the thermo's ARNT working :D Found some wiring had been melted (obviously shorted out somewhere), cut it all out rewired it all retaped it all, all good....Just started it back up then to find that they ARNT working STILL :) (starting to get really sick of this car think it'd be easier with a newer one)
Does anyone know which relay in the fuse box controls the thermo fan side of things?? Has anyone had this sorta issue before??? Before you ask YES i've checked the fuses and NO there's nothing wrong with them!!!
bloody car!! lol
Edited by Boof
https://www.sau.com.au/forums/topic/214979-thermo-fans/
Is this in a DR30? (Sorry if I am not up to speed :( )
I had the same issue - thermos not working. Actually, the thermos would come on when I turned the ignition on (for a couple of seconds), but wouldn't kick in when the engine got hot. It turned out to be the thermo fan water temp sender (in the bottom radiator tank) was faulty. A short jumper wire and some electrical tape...hey presto! Got fans!
I can't remember exactly, but I think that the fan relay (in the fuse box) is the same one as the fuel pump. I can check it out this evening - I have labeled some of it in English.
RIGHT :) After fixing my fuel leak under ze car, i started it up, only to find the thermo's ARNT working :( Found some wiring had been melted (obviously shorted out somewhere), cut it all out rewired it all retaped it all, all good....Just started it back up then to find that they ARNT working STILL :wave: (starting to get really sick of this car think it'd be easier with a newer one)
bloody car!! lol
https://www.sau.com.au/forums/topic/214979-thermo-fans/#findComment-3799244
Is this in a DR30? (Sorry if I am not up to speed :thumbsup: )
Yeah mates it in a DR30!!
Yeah that'd be GREAT if you could check what relay it was (stupid japenese on the fuse box lid) im going to try to bridge out the wiring tomorrow and see what happens!
https://www.sau.com.au/forums/topic/214979-thermo-fans/#findComment-3800411
Sorry, couldn't help you. I haven't labelled the fan relay (if there is one).
The car is away (getting straightened/strengthened) so I hope to find some time to properly label what I can. I'll take a picture when done.
If you still have a DR radiator - on the rear of the lower radiator tank, on the driver's side, is the thermo fan temp sensor switch. If you unplug it and check with a multimeter, you should have 12+ volts when the engine is running. Alternatively, bridge it with a short piece of wire, then start the car. The fans should come on.
Sorry that I can't really help you more.
https://www.sau.com.au/forums/topic/214979-thermo-fans/#findComment-3805291
Nah mate your right thanks for your help!! IF you get around to taking a photo of em justs PM me or something along those lines!!!
https://www.sau.com.au/forums/topic/214979-thermo-fans/#findComment-3806580
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
