need an r33 gtr rear diff housing, i have just the center, so need everything else along with the actual housing... located Wollongong/Sydney, but willing to travel further or pay freight
Ben
PM or email [email protected]
cheers.
https://www.sau.com.au/forums/topic/215225-r33-gtr-diff-housing/
Hey mate,
I have the front housing and stub axles from a 33 GTS-T (no rear cover), dont know if that could help with what you're after?
If youre interested just shoot me a PM :)
