Hey,
Just wondering if the DIN panel from JustJap fits straight into the console of a R33? Im planning on putting gauges under my deck (nothing is there at the moment) and was gonna make up a bracket to hold them. Although now ive seen this on JustJap and if it fits straight in that would be perfect!! Comes with 3 Gauges and a bracket to hold them!
Thanks! :blink:
http://justjap.com/store/product.php?produ...=267&page=1
