Make: 200SX
Model: S15
Milage: zero klms
Transmission: GTR 5 speed
Colour: Silver
Complied? its locally delivered
RWC supplied? no
Currently registered? no
Price: $60k ono
Contact: PM or e-mail at [email protected]
Comments / Modifications: as below
Images: yes
Hey all
Up for sale is one of the most modified and unique S15 200's in what could arguably be the world.
I could seriously go on for ages about the mods on this car but will note some quickly in point form....
  • J Racing widebody kit
  • Madhatter custom paint inside and out
  • pre tech inspected roll cage
  • brand new Tein coilovers
  • Cusco adjustable arms/swaybars throughout
  • GTR rear diff assembly
  • Highly modified body to suit GTR AWD running gear (details will be given to the buyer)
  • JUN 2.8 RB26 with twin 2835 turbos - has been rebuilt
  • Spare RB26 freshly built
  • rebuilt AWD GTR gearbox
  • Racing Hart 19" wheels
  • Advan Model 7 19" wheels
  • Exedy triple plate clutch
  • all cross members have been powder coated and are in as new condition
  • all alloy bits have been bead blasted and look like new
  • there has been 47 moulds made of which a carbon fibre interior will be made from - door trims, dash, roll cage covers etc
I could keep going but i am sure people get the idea of what has so far gone into getting the car to what it currently is. There is alot more but will go into more details when the time comes.
This car has been built under the guidance of an engineer who has guaranteed us he will follow through with engineering this car from top to bottom, front to rear.
All suspension and chassis mods/roll cage have been carried out by Performance Metalcraft over a period of 12 months to ensure 100% accuracy.
Only serious people will contact me i am sure but detailed pics can be supplied for anyone interstate and those that are local should PM me to organise an inspection time
The car is currently only a rolling shell and owes quite a bit more than the asking price.
Below are pics of what the car looked like before the conversion was started
Brad
PS - please dont waste my time by posting useless comments on the price or how you just wrecked the 'S' series chassis with the weight of an RB, we really dont care. Those that have any idea will do a quick sum on what an S15 is worth and what a Jun motor is worth.
Edited by ido09s
https://www.sau.com.au/forums/topic/215673-s15-200sx-rb26-4wd/
no i dont but it wouldnt look any different to any model GTR :)
apart from the tail shaft it will utilise all standard Nissan drive shafts and front tail shaft. Makes it alot easier from an engineering stand point
i don't think he would appreciate you blatantly advertising your car for sale in his thread.
but then again, it does show how much better value his car is.....
What he said^
Hey Brad, im from Melb and am interested. Could you please put up or send me a couple of pics of the interior (rear as well, and as much of the roll cage as possible), and a pic or two of the engine bay - let me know via pm whether you'd prefer to email the pics.
All the running gear is R33 GTR. A wreck was bought as a donor car.
Due to the car still being a rolling shell there is no rego or engineers report. Genuine, decent engineers reports are not available until the car is completed. At this point in time the owner could do with the cash in his pocket.
Props to RB26 200SX for showing us all how not to convert an S15 to RB :down:
Edited by ido09s
  • 4 months later...
Props to RB26 200SX for showing us all how not to convert an S15 to RB :)
really? why would you say that? i thought each to there own? you obvioulsy like a more stock looking 4wd 26 conversion, i like a more modified, 26 conversion... no reason for you to bag out the way ive had things done
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
