and here's my r33 series 2 1996.
lowered on some kings,tinted glass,4x345 koyas,sony double din and sony xplod high power speakers.must add the dealer put some federal tyres on the wheels and had the courage to say they are middle range quality tyre,well they are ok but dont get em wet because at the slightest touch of the accellerater they really are all over the place so dont take your mum for a spin in the wet in federals...got to go 2/10.might get a set of maxxis next, and feel a bit safer about it.
my r33 has been flawless in 3 .5 years....just an ultratune or so and a new battery and thats about all.actually a good investment!!!....but using it bit less now with fuel looking like its becoming a bit of an expensive option.
cheers......from the mansion.
-cream-
that is mental! dumped?
lol thanks.. its not always this low, just for photo purposes
going for photoshoot again this sun so will have more pics :wub:
dan another silver 4 door.. :(
Gotta admit.. looking much better than mine..
Hows chamber issues going?
lol..
well i havent driven on it long enough yet to exp tyre wear but its running quite a bit of camber
Edited by dori32
Update..
For those who dont know..
the GTR bonnet is Alluminium and light as a feather.. even copaired to the heavy weight GTST bonnet.
Saved just over 15kg :D
Have another trick or two up mt selve once it is at the paint shop :)
Oh.. just a question..
Help me decide..
Do I;
A) Paint the bonnet and grill silver to match the rest of the car
B) Paint the bonnet matte black and the grill silver
C) Paint the bonnet and grill matte black?
Help me decide..
Do I;
sorta matches your wheels as it is now...have you got future plans to upgrade those?
you could always be different and paint your A and C pillars along with the roof and boot the same colour as whatever the bonnet is!
tho i dunno how that would look....
prolly a bit lame...
but originality!
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
