shannons are idiots, i had a person hit me on the side and the accident wasnt my fault at all and they want me to get a driving history, when everytime i get a fine or what ever i ring the person at shannons of which i have been dealing with for the past 5 years and let him know.
so repairs wont comence until i do that, which i crap when i wasnt my fault the guy turned in to me on a straight piece of road the police even stated that also motor reg is open 8:30-4pm and i work 8:30-5pm and Steve will vouch i dont really get a lunch break ever so i cant go down there and anyway it costs money.
Anyway i have spoken to a few ppl in the industrie and they even cant understand why im being treated like this
so thats why im going through the company that hit me
If i could use race tape to fix it i would luke lol
the way i got mine done fast is u just keep calling them, there will be an adelaide branch of ur insurance company just call them every single day and ask if its moved forwood a step.. i did this with both my write offs, the 1st 2 weeks or so are slow coz they get shitty with u, but after that they just get over it and hurry up :P as for the petrol situation... b less boost happy haha i duno!
mine is shannons full comp and 115.00 pr month idiots
his i dont know they wont tell me i have to wait until tuesday if i havent heard from the assessor to call back
I'm sure they're obligated to inform you details of their insurer. :P
yeah i'd be going after him a million miles an hour. If he's admitted liability, then pester him daily for either payment or his ins company's details.
A formal letter to him giving him 7 days to respond with his intentions would've been the way to go....if you don't get anywhere with him and you still want to go with a letter, you might be able to use my companies letterhead. Official letters tend to speak louder than personal ones.
Alternatively, depending on the exact details of the accident, I'm happy to give him a ring for you and see if I have better luck. Unfortunately he probably sees you as someone he can stuff around and draw the whole process out.......people like that annoy me. If he is not accepting liability, that may explain his lack of cooperation.
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
