Does anyone have a buggered R32 rear bumper lying around or know of any wreckers where they may have seen a smashed rear bumper or a rear-ended R32? It can been pretty much absolutely stuffed as I only need to cut a piece out of it to repair an existing bumper.
Any suggestions regarding where I may be able to find something like this would be great.
https://www.sau.com.au/forums/topic/21612-looking-for-a-smashed-rear-bumper/
