hey steve how low did that pipe sit? do u have a pic of it on the car... a frontal?
the thing that put me off about it was bottoming out and smashing the pipe
https://www.sau.com.au/forums/topic/21633-r32-fmic-4-sale/#findComment-458426
Hey,
um if you are refering to my cooler it never got newhere near touching the ground, my front bar did but not the IC,
here is a frontal pic and as u can see it clears it by heaps.............
Steve
https://www.sau.com.au/forums/topic/21633-r32-fmic-4-sale/#findComment-460155
