Hey Guys.
I got rid of the 32 4dr and got a new toy.
All you adelaide Boys/ Girls will be able to see this out at Mallala Rd 3 DA. And other Practice days/ comps.
Below are the specs for the thing
The car is a 1992 Toyota JZX81 MarkII "Yamaha Edition" (1 of 300)
The motor and all accessories were built and assembled in house at HKS Kanto, Japan
It has:
1JZGTE Motor (claimed 10,000kms since HKS build)
HKS stainless exhaust manifold
HKS 3037S turbo 480ps rated
HKS 50mm External Waste gate
HKS 264 degree Cams
HKS 1.6mm head gasket
Custom HKS Intake Pipe
Custom HKS cooler kit
HKS 3 core radiator
HKS oil cooler kit with remote oil filter
Custom HKS catch can
HPI tourque dampener
HKS 540cc injectors
Tomei Fuel Pump
3 ½” straight through exhaust to a custom HKS Muffler
screamer pipe from external wastegate
Custom HKS front pipe
HKS thermostat
Autronic SM4 Stand-alone ECU (3bar map sensor) running a custom wiring loom, mounted in the stock ECU position (out of sight) with a glove-box mounted data cable.
LS1 Coilpacks custom mounted with 8.5mm leads
Wheels: BBS mesh 17 x 9 +20 all round
R154 5 Speed Manual Gearbox
OS-Giken Twin-Plate Clutch
TRD 2-Way LSD
Rear subframe modifications (extra weld bracing + mounted closer to chassis to maintain suspension geometry)
Kei Office Coilovers (custom specs) "Tezuka Model" - Front-10kg Rear-8kg
LARGUS sway bars front & rear (extremely thick) with pillow ball links
Strengthening rear Tie Rod's
R32 GTR Brakes (front: 4 spot alloy callipers)
HKS braided brake lines
HKS braided clutch lines
Strengthenned front Stub Axle links
Strengthenned front toe arms
Modified steering knuckles (for stupid amounts of steering lock)
New Wheel bearings all round
All bushes replaced recently
Free Dom Boot brace
Free Dom Floor brace (monkey brace)
Free Dom Rear Pillar brace
Tanabe Sustec Front Strut brace
Chassis Seam welding
Dart Izumi “Destructive King” front bar
Free Dom side-skirts
Hippo Sleek rear bar
Original "Yamaha Edition" rear lip/boot spoiler
Front & rear wheel arches all custom hand flared ~20mm
Free Dom single layer Carbon Fibre vented Bonnet
Clear indicators w/ blue side lamps
Dark tint rear passenger windows and rear windscreen.
Nardi Steering Wheel
Grex gear knob
Blitz Boost Guage
Greddy Gauges: Water Temp, Oil Temp, Oil Pressure, Exhaust Temp
Blitz Electronic Boost Controller – Dual SBC-R
Bride Brix Drivers Seat
Bride “Super-low” drivers sliding seat rail
some double din CD player
About the car:
The car is a special model of the JZX81 called the "MarkII Yamaha Special" one of only 300 produced from toyota. It was used as a daily driver/slider by an associate of none other than D1 driver Tsuyoshi Tezuka, who's shop Kids Heart tuned the suspension set up for drift. It has also had a small feature in a Japanese drift magazine.
The Autronic has been setup with a very safe tune by a very experienced local Adelaide based tuner (before turbo rebuild/upgrade). Running BP Ultimate, the car makes 280rwkw on only 16psi (limiter set to 7500rpm) with excellent turbo response, making the 16psi @ ~3600rpm, and making 200rwkw by 4000rpm. This was on the old turbo, the rebuilt set up seems even more responsive again, making full boost at around 3000 rpm.
https://www.sau.com.au/forums/topic/216472-the-new-sedan/
Cejay this car was imported by Iron chef imports and has since been owned by 3 ppl, all with the intent to slide it but its only been on the track once :blush:
i look forward to seeing if brenton can A) see over the steeringwheel/dash and B) drive it to its full potential....
https://www.sau.com.au/forums/topic/216472-the-new-sedan/#findComment-3825588
Cejay this car was imported by Iron chef imports and has since been owned by 3 ppl, all with the intent to slide it but its only been on the track once :P
:whistling: with my Bride in it? No he couldn't hahaha.
I hope you have fun with it mate, I'm having fun with your 32 :P :P
https://www.sau.com.au/forums/topic/216472-the-new-sedan/#findComment-3826171
  • 3 weeks later...
Some recent pics from the All Japan Day in April.
And also a few pics from todays private track day.
Had a bloody ball in the car.
Can't change a thing on it at all.
But might need to get some chewy to hold the rear bar back together.
Will have some footage of todays efforts up shortly.
And will have some pics from Round 3 DA this weekend.
Toodle pip boys and girls
https://www.sau.com.au/forums/topic/216472-the-new-sedan/#findComment-3887784
well HELLO TRISTO.
HAHAHAH hurry up and get back out on the track mate.
Want to have some competition at my level.
Oh and I will hopefully have footage of me up shortly.
Just gotta wait to get it from the guy who was out at the private day the other week
https://www.sau.com.au/forums/topic/216472-the-new-sedan/#findComment-3912287
  • 2 months later...
here are said pics of me from G1 rd 2.
Was fighting the car all day as something isnt right with the alignment. Oh and the rear wheel bearings a fingered.
came off in a big ass puddle. couldnt see alot
WEEEEEE one of the many spins I had.
Hope you all enjoy.
Brenton
Will mos tlikely put this up for sale soon as i haven't got my heart in the right spot to continue drifting.
Looking for a lightly modded R34 sedan or Series 2 Stagea at the moment.
Sooooo im loking at around $18k.
https://www.sau.com.au/forums/topic/216472-the-new-sedan/#findComment-4064644
FK dude, seriously want this back hey. One thing I regret is letting this go under the circumstances I did.
If you are genuinely keen to sell, contact me and we'll talk. I have unfinished business with this car :cool:
https://www.sau.com.au/forums/topic/216472-the-new-sedan/#findComment-4066918
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
