Hi all, for those in the know what is the best/Optimal A/F ratio for our skylines? Given no detenation of course. I have been told 12.3:1 is were max power is made on a turbo charged engine however have seen GTR's tuned down to flat 13 and make more power. Are we talking a combination of the best ignition advance curve versus A/F ratio?....ie car X might make more power with slightly richer mixtures and more advanced timing were as car Y will make more power with lean mixtures and a tame timing curve.
Are there any proven ignition timing levels for max power on an RB25 or is it more of a matter of having the timing a couple of points below detenation?
Is there a optimal A/F ratio that has seen the best results in
power?
Peak torque is around 5200-5500rpm, is detenation at this point best controlled by reduced timing or enriched mixtures?
I'm thinking something along the line of "a can of worms"
The reason I ask is because I have an narrow band oxy sensor and meter that I am using on the weekend to check my A/F ratios.
Any advice on road testing and tuning(Power FC) would be greatly appreciated.
https://www.sau.com.au/forums/topic/21655-best-af-ratio-for-rb25/
I think around 14:1 is the "perfect" mixture, but this will not cater for any variances such as turbulence in the plenum, injectors not flowing *exactly* the amount they're supposed to, etc. That's why cars are usually tuned to around 12:1. 13:1 would be better if you could get it reliably, but it'd be risky if you haven't got everything tuned absolutely perfectly and compensating for temperature.
The "best" mixture depends on the car. Some will show a big jump from 11:1 to 12:1, some will have smaller differences. My car seems happy enough at 11.5:1. The richer you can leave the car, the less likely you are to detonate. My car could run happily all day at over 12:1 during winter, but in summer without anything to compensate for the temperature it would probably ping. That's why my mechanic tuned it to 11.5 or so.
BOOSTD, mine is currently tuned at 12.2:1 on boost. Done at tilbrooks at the beginning of this year, in the morning probably around 25deg C.
In corky bell's book supercharged, it recommends around 13:1 for on boost (above 1psi on the boost guage), down to 14.7: at atmosphere (0 on the boost guage). Idling (20 inches of vacuum) he recommends around 15.5:1. He describes that cruise is at about 10-15 inches vacuum, but doesnt give a recommended ratio, he does however say that it is in between.
He says that the on boost isnt the hard part, the part thorttle at different rpms/loads is 90% of the work and recommends looking at 500rpm increments.
In the book 21st century performance, it describes lean (18:1) cruise mixurues, but this generally requires a good ecu and closed loop as slight increase in load will rapidly increase the requirement for fuel.
Thanks Steve. Did Martin or Mick tune your car? I will find out exactly what my car is doin tonight, both martin and mick have played with my mixtures.
I have the book 21st Century Performance....can't remember how many time I've read it cover to cover.
Any insite on the Ignition side of things??
Sorry I have no idea about the timing, I am pretty sure mine is set to stock (15deg), so I am not sure if they just used stock timing and adj fuel to suit. When it first went on it was running a little advanced, they wound it back as it was pinging pretty bad at about 6200rpm. Dont have any idea what is happening with the ign maps either. Sorry (keep meaning to take a closer look there)
I dont have corky bells book with me at the moment (at work), but I will have a look to see what he says about ign, and post it up this arvo. If you want to borrow it, its a bit thicker than 21st century performance, likewise it definatley requires a few reads to absorb.
I had a thought about the above post too, I am not sure what fuel they were recommending those ratios for (ron), he just stated to start there and add in as needed:)
Martin did the tune.
Corky bell does mention a bit about ignition. Basically he states that as boost goes up, you need to pull igniton from the off boost maps. Goes on a bit about the differnet factors, such as AF ratios, temperature, octane, etc.
If you like I will give the book to hippy when he picks up the wheels, and he can pass it on:)
Hippy, you are most welcome to borrow when BOOSTD is finished, or there is a motoring book shop in the city on Gouger st ( I think), opposite the markets/cafes. Corky bell also writes a book called Maximum Boost, which is the same price as supercharged, and goes a bit more in to turbo specific applications. Well worth the $100.
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
