Make: BMW
Model: 1980 318i E21
Milage: UNKNOWN
Transmission: 4 Speed manual
Colour:Alpine White
Currently registered: NO
Price: $1500
Contact: Darryn 0421025848
Comments / Modifications: For Sale: 1980 318i BMW – Alpine White
318i: An upgraded version of the 316 featuring the M10 1.8 L engine fitted with a Bosch fuel injection system, 4 speed manual
Last registered 2006, One owner since new
Good tyres and New battery (purchased prior to going in storage)
Body has some minor rust appearing (see pics), otherwise straight body.
Engine and driveline are mechanically sound
Would need minor work and service to make daily driver, would be great to restore!
Kilometres are unknown
Reason for selling:
Has been sitting in garage for two years, require space for new vehicle, I had planned to restore but no longer have the time or storage space.
The car will be sold in ‘as is’ condition.
Feel free to email any questions. If you would like to view the car in person email me you number and I will call you to arrange a viewing. The car is located in Adelaide (5095)
Trade/Swap: Dont want to swap for another car, i have a Stagea and a Surf, would consider trades for any parts, eg mags, stereo etc.
Images:
Edited by stageabandit
https://www.sau.com.au/forums/topic/216599-1980-318i-e21-bmw-adelaide/
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
