Tein Spanners
Guest Boxhead
I ordered one of these spanners from autobarn(hey i have contacts so i dont pay retail) basically after my initial adjustment of my suspension i was thinking maybe i could send my spanner to a fitter and turner i know to get some more made up... if anyoen wants one, ive heard that 1 spanner does the lot as in its just one spanner for all models... so register your interest and i will see what i can do, also, if you can tell me how much you willing to spend to see at what i can do if there is quite a few of you...
Michael
[email protected]
https://www.sau.com.au/forums/topic/21694-tein-spanners/
YOu can buy after market C Spanners adjustable type from good tool shops such as Tool Works at Castle Hill 02 9894 6546 or Wholesale Suspension in Penrith from about $40 each and fit all coil overs.
On the topic of Tein though and prob a lot of other Jap made coil overs they are often too hard for Australian road and race tracks and for that matter even the smoother Japanese tracks. The Japs don't always get it right.
I have the Tein HA adjsutable shock and height Teins and found the rear of my Zed TT to be quite hard even on the softer settings, It over steered a lot and did not brake as well as should as well as got unsettlesd over bumps such as turn three down the hill at Eastern Creek. I took out one fo the front and one rear and sent of to Eibach, who only make the best springs in the world probably. Anyway they dyno tested the shocks and found them to be quite hard even on the softer setting especially the rear. The springs in rear were also too hard. Factory around 250 pounds and the Tein were 570 pounds. They changed to a twin spring, the heavier being a 440 pound spring with a Tender spring of prob 150 pounds. Bottom line 3 secs a lap faster and did a 148 with a passenger ( Akira) who also has hard Teins in his car. Much nicer for road cars also.
Guess what Skyline Teins have even heavierr springs,both GTR and GTS-T yet the cars are lighter so guess what, "Good is the Enemy of Better" If you have coil overs and think your skyline handles well it can be much better and if a zed passes you at the track then consider. he he.
https://www.sau.com.au/forums/topic/21694-tein-spanners/#findComment-518460
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
