Tein Spanners
Guest Boxhead
I ordered one of these spanners from autobarn(hey i have contacts so i dont pay retail) basically after my initial adjustment of my suspension i was thinking maybe i could send my spanner to a fitter and turner i know to get some more made up... if anyoen wants one, ive heard that 1 spanner does the lot as in its just one spanner for all models... so register your interest and i will see what i can do, also, if you can tell me how much you willing to spend to see at what i can do if there is quite a few of you...
Michael
[email protected]
https://www.sau.com.au/forums/topic/21694-tein-spanners/
YOu can buy after market C Spanners adjustable type from good tool shops such as Tool Works at Castle Hill 02 9894 6546 or Wholesale Suspension in Penrith from about $40 each and fit all coil overs.
On the topic of Tein though and prob a lot of other Jap made coil overs they are often too hard for Australian road and race tracks and for that matter even the smoother Japanese tracks. The Japs don't always get it right.
I have the Tein HA adjsutable shock and height Teins and found the rear of my Zed TT to be quite hard even on the softer settings, It over steered a lot and did not brake as well as should as well as got unsettlesd over bumps such as turn three down the hill at Eastern Creek. I took out one fo the front and one rear and sent of to Eibach, who only make the best springs in the world probably. Anyway they dyno tested the shocks and found them to be quite hard even on the softer setting especially the rear. The springs in rear were also too hard. Factory around 250 pounds and the Tein were 570 pounds. They changed to a twin spring, the heavier being a 440 pound spring with a Tender spring of prob 150 pounds. Bottom line 3 secs a lap faster and did a 148 with a passenger ( Akira) who also has hard Teins in his car. Much nicer for road cars also.
Guess what Skyline Teins have even heavierr springs,both GTR and GTS-T yet the cars are lighter so guess what, "Good is the Enemy of Better" If you have coil overs and think your skyline handles well it can be much better and if a zed passes you at the track then consider. he he.
https://www.sau.com.au/forums/topic/21694-tein-spanners/#findComment-518460
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
