I recently got done for speeding along wanneroo road where a stretch of it drops from the normal 70 down to 60 (which I didn't know... thought all of wanneroo road was 70!).
I got pinged by a cop with a handheld laser doing 82km/h, and he only allowed a 2km margin of error bringing it down to 80km/h shafting me with a $300 fine and 3 demerit points. I know that multanovas must allow for a 3km margin of error, but the cop was being uncooperative and obviously wanted to get his quota up and put me in the 20-29km bracket rather than the 10-19km/h bracket which would have been less money and points.
Now my question is what is the margin of error police have to allow for HANDHELD speeding cameras? I've been searching on the net but can only find the margin for multanovas. A link to the source would be helpful.
I have no problems with paying a speeding fine if I get caught, but I do have a problem when I think the cop is breaking the law to penalize me more.
https://www.sau.com.au/forums/topic/217331-margin-of-error-for-handheld-lasers/
  inthisglass said:
count yourself lucky he gave you the 2kms..
he could have stung you with the 30-39km bracket..
That makes no sense... He wasnt anywhere near 30ks over and the 2 ks he did give made no difference to which fine bracket he was in...
  ztuned said:
yeh and 2+2 = 6.3
I thought it was 2+2 = 100
Darn... looks like I need to retake my math class again :D
& which section of wanneroo is this on?
I know that the section where I travel alot on (the section near along dogswamp) there is a slight hill going up & they like to put their speed cams there. Was working along that road once & notice tons of cars getting flashed >_>"
Edited by Mayuri Krab
im pretty sure its 2km error as lasers are more accurate then mutinovas. shoulda said it was the car infront/behind, i got away from that excuse before which was darn lucky on wanneroo aswell just after morley dr. intersection. did 40km+ on tonkin hw and had 7 points taken off with 1k fine. since then ive bought myself a radar detector. they work good but only if your doing less than 90kms in order to stop in time.
Gazza is right with the 10% speedo calibration... they only have to make their speedos accurate within a 10% margin. You never know, you might have a speedo that is dead on but with 10% margin for error up their sleeve it's doubtfull.
The lasers and multanovas do not have any margin of error. Each unit (in a perfect world) is tested with a tuning fork and calibrated. There will be actually variences due to the angle the laser is fired from (eg two lanes of traffic, cars side by side... car closer will be slightly different to the car further away)... the good thing there is that cops kow this and they will usually (as they have in this case) removed a little for angular margin of error. Unfortunately with multanova's, as they are a basically an automatic letter in the mail after a quick photo review, there isn't anyone who will down grade your speed.
What this means is that you could be thinking you are doing the right thing on the freeway, putting along at 100km/h on your speedo and then get flashed actuall doing 110km/h... on a long weekend thats going to cost you $150 and 4 points thanks very much Mr Car Manufacturer.
Flip side is you could be over on your speedo and actually under the speed limit... fingers crossed all of our speedos are this way inclined.
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
