Hey just figured there hasnt really been much cruising going on lately so i thought id see if anyone's keen to go for a spin on sunday. could plan it for later with more warning but then we cant really tell what the weather will be like. i was thinking afternoon as to allow peoples hang overs to settle
so far weather is looking at;
Sunday Fine. Mostly sunny.
top 22
which is a lil chilly but the turbo's will love it
if there's enough interest ill whip up plan if not stuff you all sit at home n do nothing you anti socials :P
Edited by gzilla
https://www.sau.com.au/forums/topic/217414-cruise-this-sunday-on-4th-may/
  • Replies 46
top 22
where are u planning on going?
geez now ur putting pressure on me to come up with something. i was thinking some kind of winndy road ill try n dig up my bros cruize notes. was thinking maybe the castle for pics or devils elbow not sure yet ill see what notes i can dig up.
ofcourse naturally if it rains sunday consider it cancelled people :D
if you wanted to do somrthing tomorro, my mates are cruising to motor meusuem, birdwood.
i believe they are meeting at parafield bunnings. at 10 am
i wont be there, coz tomorro is the only chance ill have to flush my radiatior...
just a suggestion.
Hey dude, should meet up before the meeting spot then go there. =D
yeh im up for it! gotta get my cusco's in! and my gtr bumper on! and ill be ready! but ill be driving with a black front bar on a maroon car haha oh well!
there we go think thats a pm for everyone.
Reuben just bring the moto on our cruise :)
for people coming along as always remember its not a race so leave any hoon driving at home on the playstation and we should all have some fun :(
if i missed anyone let me know and ill try and get a message out to you or hopefully someone else can help ya out with the details
Edited by gzilla
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
