how old r u, an if u got no mrs then i can pm u when i get a call from a few slappers, lol..
pretty much all me and a few mates do these days, work 7 days a week, an really to tierd to do the clubbing thing, but plenty of time for the sshhlappers lol
i dont wanna go clubbing or ne thing i just up for going for a bit of a drive . i think sky...cab wants to aswell
next time someones bored...make it an event/cruise- we would have had at least 5 cars yday for a little cruise (and im sure more people would come if posted). il post up as soon as i get my adjustable caster rods.
Edited by marlon
