HI GUYS,
I am having problems with my hicas light.
The light turns on about half an hour of driving and the back
wheel kicks out.
If i turn the car off then on again the light goes out.
The car is a 1993 R32 Gts4t.
Has anyone ever had this problem before i have taken the
car to several mechanics and no one has been able to
fix the problem.
Any suggestions will be greatly appreciated.......
https://www.sau.com.au/forums/topic/21788-hicas/
Hey Enrico,
We have found the problem when you put your steering wheel on make sure it is perfectly straight and the hicas sensor is in the right place.
what happens is when you have been driving for over 20 minutes the computer senses that you cannot be turning all that time and has a dummy spit the arse end kicks out and light comes on.
I had been to many mechanics here in sydney and none of them
knew what they were doing some supposed import specialists.....
Try this and let me know how you go.
Regards,
Daniel
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-477187
I am not sure about where the dead centre is i have tried to get the wheels as straight as i can and re fit the wheel.
No luck its still a bit off centre i will try moving the wheel i notch
again tomorrow.
If that doesn't work i am going to Unique Auto Sports on saturday for a service i might get them to have a look into it and
see if there is something i am overlooking......
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-482053
OK
There was something i overlooked.
ON the rod where the wheel fits onto has got a mark on it and geuss what i am 99% sure that this is the top dead centre mark.
Also on the standard wheel there is a mark on the top centre....
How stupid of me to overlook that i must have been drunk.
Hopefully this fixes my problem and more importantly helps someone else.
With the aftermarket wheels make sure you have a hicas boss kit with any luck they will have a mark top centre aswell and so they should at around $250AU ea.
I haven't seen one as of yet i am on a pretty tight budget and would rather do some performance mods than anything else.
Well thats enough crapping on from me i will be updating again tommorrow night with how it goes need to go on a freeway to test it out properly...
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-484017
Well i re-positioned my steering wheel today, and the light hasnt come on since so lets hope its all goot now!. However a funny thing hapened when i was driving home. I turned on my hi beams, and for a split second the Hicas light turned on, then turned off. Wierd. the globe hasnt blown thou.... Anyone have any ideas??
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-487577
Well im pissed off still not workin dont know what to do now.
I had the car serviced today and have been told that the front end bushes are F**KED and they will need replaceing.
Dont know if this could be contributing to the problem.
Might have to take it back to UAS and get them to have a look at it for me.
Dan
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-488216
I have a '93 GTS-4 and I am also having a problem (I think) with my HICAS, my light stays off while I am driving and all that, the fluid levels are all full but the back end seems to be kicking about now and then, especially when I go over high gaps in tarmac (like at the start of different surfaces with dodgy roadwork and bridges).
Does anyone know what might be the problem?
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-488505
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
