Cool. It sounds like they do have some experience in body work and such.
But what about mechanical and engine wise?
Yes
They picked up the small dents in the car (now fixed) and some other nice pick ups I would have missed, however their idea of near perfect interior left a lot to be desired.
Well the guy seems to know at least the basics. I could not point to anything that has since gone wrong that they should have picked up on.
Remember every person who inspects a car is different. My choice was a local NRMA authorised fellow from the Ford dealership or driving a specalised inspector down from State Roads. I did not see any difference in inspection from previous NRMA inspections, but State Roads were able to email me the inspection etc the same day.
  • 2 months later...
I have had 2 cars inspected by them recently. They are definitely worth using but the seller will tend to deny anything thats picked up so you cant get further information about why a respray has happened or why the back tyres are bald etc.
They will pick up on things you will miss but they will also miss atleast 1 thing.
In my case they picked up cosmetic repairs but said it woulda been a scratch and not an impact, but I noticed before the inspection that the same panel was slightly inconsistent compared to the other side which suggests a bingle as oppose to just a scratch, maybe I am wrong though but the owner was tight lipped(complete denial) so it must of been an impact.
Another car they completely skipped the dirty condition of where the doors met the body in between the seals, but picked up on a lot of other things.
Cosmetically you could pick up on anything they could apart from a really good respray without bodywork or things under the chassis, it would just take you 4 times longer to do.
They are familiar with models and what are model specific characteristics(Nissan have noisy 1st gears), but the 2 mechanics standards differed so average for one mechanic could be good for another.
Edited by NissanFan
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
