Car: 1993 R33 GTS-T Skyline
Engine: RB25/30 DET
Engine mods:
Balance & blueprinted engine
CP Forged Pistons
Eagle Rods
Nitride Crank
Custom Oil Pump Drive
Custom 8.5L Sump
Nismo N1 Oil Pump
Tomei Poncams
Tomei Cam Gears
ARP head studs & bolts
O-ringed RB30 block
Ported & polished head
Copper Head Gasket
GReddy plenum
90mm Q45 throttle body
Sub Zero 600x300x120mm front mount Intercooler
Brass 3-core Radiator
T-72 Mr. Turbo Billet Turbo
50mm HKS External Wastegate with screamer pipe
X-Force Exhaust Manifold
3" Mandrel-bent Exhaust with 5" muffler
Turbosmart Type-2 Blow-Off Valve
GReddy Profec B II Boost Controller
Microtech LTX-12 ECU
Nismo 600cc Injectors
GReddy fuel rail
Bosch Motorsports 044 Fuel Pump
Nismo N1 Water Pump
Cusco Catch Can
Blitz C1 pod filter
GTR rocker covers
Trust RB26 clear cam gear cover
GReddy oil cap & radiator cap
Driveline:
C4 Auto gearbox - fully manualised with 3 speed reverse shift pattern
TCE 3500rpm stall converter
B&M Pro-ratchet shifter
Transbrake
Gearbox oil cooler
Custom S14 diff housing
R34 GTR 3.5:1 diff gears
Custom tail shaft with billet yoke
Brakes & Suspension:
DBA slotted front rotors
Gold painted brake calipers
A'PEXi coil overs
Cusco strut brace
Wheels & Tyres:
Street-
Starcorp Impul Shadow Chrome Wheels 18" x 8.5
with Falken 235/40 tyres - front
Starcorp Impul Shadow Chrome Wheels 18" x 9.5
with Falken 265/35 tyres - rear - *tyres near new*
Race -
R33 GTS 16" wheels with Mickey Thompson 255/50 tyres - *tyres never used*
Exterior:
Standox Daytona Paradise Chameleon paint (green to blue to purple)
Carbon-fibre Bonnet - T2
GTR rear wing, side skirts & rear pods
Modified Tommy Kaira front bar
Nismo clear side indicators
Tinted Windows
OOR33 personalised plates
Fusion Green underbody neons
Interior:
Green vinyl/Black leaather re-trimmed seats - front & rear, door trims, hand brake boot & centre console
'R33' gold embroidery on front & rear seats
Standox Daytona Paradise painted dash surrounds & vents
HKS Turbo Timer
A'PEXi Rev/Speed Metre
GReddy boost gauge
Autogauge 5" tacho
MOMO Millenium Streering Wheel
Mongoose alarm
Stereo:
Sony CD head unit
Sony 6 Stacker
Fusion 6.5" splits - front
Fusion 6.5" speakers - rear
Fully trimmed boot install with green neons including -
2 x Fusion 12" subs
2 x Fusion 4 channel amps
Fusion 1.5 farad capacitor
Performance - 453rwhp @ 18psi (easily make 500+ with new set up).
Price - $39 990 negotiable
Location - Brisbane
Other information -
Much loved car - regretful sale - selling due to new baby.
Car always looked after - very reliable yet quick street car - Low K's since rebuild - approx. 10,000 on engine. (122,130 showing on clock).
Have owned car for over 6 years (bough car completely standard) & all modifications have been done since purchase. Approx. $100K spent on modifications.
Street driven by female owner.
Featured in Hot 4's, High Performance Imports magazines & Ignition DVD.
Multiple trophy winner including 2 Autosalon trophies.
***MUST GO - MAKE AN OFFER***
Edited by oor33sky_
https://www.sau.com.au/forums/topic/218828-fs-1993-r33-skyline-rb2530-gts-t/
How much for the engine dude?
would definitely prefer to sell car complete, but would consider separating if need be...
throw me an offer & I will consider or keep in mind for down the track...
am also open to offers of swaps + cash
am interested in S2 Stagea or similar...something like the Cheese Stagea (shame it looks like it's now sold :P )
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
