  • Replies 264
Nicholsons is always good... fairly cheap to and a good big carpark
http://www.nicholsons.net.au/
+1 for Nicholsons, they have a mean steak sandwich!!! Yummmmmmm
Keep on Topic, this is not a Whore Thread,
Bwhahahha
I would like to go, so I could bag out all the Uni students...... Looking at you Brady!
This isn't the boy scouts..
This is what we do...
okay so who wants to decide what...
less talking and let's actually make this less confusing...
and still, bnr#@... what's ya name dude i'll put you on the list and Coz are you going to come?
who else wants to come?
cheers,
Andrew :spank:
Seriously dude...
Best way to sort this out..
Make a poll, run it for a week/10 days... Then book to whichever has the highest number of votes..
That is my best suggestion... Some ppl are going to be pissed, but it is the most democratic option...
democratic eh... :P
where is this Nicholson's place?
a drive to Fremantle would be nice, i think with the plans we already had everyone was happy with that but i guess we can try to work something out...
had 14 people happy with Fremantle, if anyone has any objections just let us know and we'll hold a poll i guess, i have no problems and we have some time but yeah voice your opinions now eh...
i don't know how to create a poll either :spank:
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
