hey dude i'm in vic and i just recently did the same conversion in my 32. i just told them i blew up my old engine (rb20det) and had to put a new engine in (rb25det). All they asked for was the recipt for new engine and to veiw the engine number in the car (to make sure it wasn't a stolen engine, i would imagine). Oh and i just said it was the same sort of engine to avoid questions about having a bigger engine.
https://www.sau.com.au/forums/topic/218843-25-powerd-32/#findComment-3860767
So did they pull you up on the engine number, because you saying that its an rb20, with an engine number rb25xxxx is likely to get you in trouble. its an increase in power and capacity so most of the time you need an engineer's cert. but thats just in vic, cant comment on other states.
https://www.sau.com.au/forums/topic/218843-25-powerd-32/#findComment-3861820
Nah not at all, 20 or 25 same thing to a stock person haha. you have to remember that 99.9% of people wouldn't know that r32gtst's come standard with rb20det's and r33gtst's come standard with rb25det's. so unless the person viewing the engine number is a mechanic that knows alot about skylines then i'd think you'd be pretty sweet.
https://www.sau.com.au/forums/topic/218843-25-powerd-32/#findComment-3864212
It worse than that. 'Stock' people (what, like they're friggin' cattle?) wouldn't know what the noise is coming from under the bonnet.
https://www.sau.com.au/forums/topic/218843-25-powerd-32/#findComment-3864247
Soon as an officer pulls you over - off the road you'll go with the illegal engine conversion :P
Police know what it all means. And can see if you've been engineered or not, if you haven't, bye bye :(
I know quite a number of people who've been instantly put off the road for that kind of thing.
https://www.sau.com.au/forums/topic/218843-25-powerd-32/#findComment-3864411
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
