I have an R34 bootlid which has had the holes welded and has been resprayed. I am happy to swap it for a bootlid which has the standard R34 wing. Doesn't matter what colour as I can have both the bootlids resprayed. My number is O438 753 678 if anyone is interested. I will post pics later on.
Matt
https://www.sau.com.au/forums/topic/219577-r34-bootlid-for-swap-white/
Matt
Sedan or coupe? Is yours White or pearl white?
MATE, I'm definately keen. I took my wing off(still have it at home) and I haven't filled in the holes yet. I could reattach for you, then swap for your boot with the holes already filled in. I got a white 34 coupe. PM me if you are still keen, I am!
