I have had hours and hours of dyno tuning on a mircotech.
Cold start I had to sit on the starter for like 10seconds to get it started. (Haltech starts right away)
I would pull up at lights and the car would stall. (Haltech running idle has had zero problems.)
Haltech is so much better for GTR's (Due to 6 throttles).
All was turned by the same tuner.
https://www.sau.com.au/forums/topic/219592-microtech-lt8s/#findComment-3878435
Not true, it is common knowledge that single map sensors struggle with multi throttle arrangements, hence why PFC d'jetro uses 2 sensors, and autronic uses TPS/MAP combined.
^^^^ On the money!!!!!!^^^^^^^ >_<
https://www.sau.com.au/forums/topic/219592-microtech-lt8s/#findComment-3878452
  • 2 months later...
sorry to drag up an old thread, but dont all map based ecu's need throttle % input?
i had a ancient map based haltech e6a & that was .
im only asking cause im considering a s/hand microtech lt12s
Edited by norwest_rumbler
https://www.sau.com.au/forums/topic/219592-microtech-lt8s/#findComment-4072727
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
