i have for sale one Trust Greddy E-manage Blue.
it comes with.
*Main module
*Main harness
*universal injector harness
*universal ignition harness
can be wired up to fit almost any car.
YES this is a piggyback computer.
i purchased this only recently but have decided to go another path, it was previously used on an R34 GT-T but everything looks brand new and the 2 universal harnesses have not been used.
located in sydney.
$350 pickup
$365 postage anywhere in aus
PM or post here.
Cheers.
located in sydney.
https://www.sau.com.au/forums/topic/220700-fs-greddy-emanage-blue/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
