MonstA T3/T4 600HP TURBO Brand new never Used
The T3 / T4 MonstA Turbo are custom matched for specific applications.
Airflow ratings to 600 HP.
Consists of a T3 turbine section, (standard, Stage II or Stage III trim) and a T4 compressor section (T04 trim).
The turbo offers the low inertia and fast boost response of the light weight T3 Turbine wheel and the
high airflow characteristics of the T4 compressor. Air flow rating of up to 600HP
3" Inlet Diameter : 2" outlet
Wet Floating Bush Bearings : 1/8 NPT oil inlet
T3 Flange : Fits T3 and T3/T4 Manifolds
Specs:
. 50 a/r compressor
.63 a/r turbine
.57 trim
Turbine wheel:
Exducer: 2.48"
Mayor : 2.89"
Compressor wheel :
Exducer: 2.07"
Mayor : 2.36"
I Payed $474 including the postage and handling (RRP for the turbo is $440 + $34 postage)
Im asking for $450 cash or nearest offer. Its brand new so no low ballers. serious buyers only!
im not shipping interstate either its pick up only. Item is located in sydneys western suburbs.
you can contact me via pm or via my mobile number : 0433750636
Kind regards
MR. Flawless
P.S. If you dont like the Price....Tuff . Dont P.M. me or post about it because i dont have time for it, and dont pm me low balling me saying you could get it cheaper somewhere else, because lets face it, if you could get it cheaper somewhere else, you wouldnt waste your time trying to hustle me would you?
Edited by MR FLWLSS
i have seen these turbos used on other cars and they work quite well i have used them before. the fact that u criticise and call it a paper weight is quite funny. if its no goood why would you even offer money? the answer is your a low baller. i have had direct experience with these turbos. which i know for a fact do work quite well. . witch brings into question a certain group of low ballers technical ability to work on a motor vehicle.... Im a mechanic by trade and i have worked with import cars since i was 16. the most i see some people here have is the technical ability of a key board mechanic, ie:some one who thinks they know/a wanna be/the guy who herd that form a guy who herd from another guy who said/follower. now as posted in the top of the topic i dont care if you dont like it i dont care if you wanna low ball. i dont have time for it. go talk to someone who gives a rats arse. and allow the sale to continue with out a bunch of low ballers tyring to gang up on someone who quite frankly doesnt care about what a group of under qualified morons has to say.......
Now the price is $300 firm. im not negotiating any more due to a bunch of lowballers. if you want it take it if you dont want it, dont take it. its that simple.
Kind Regards
MR FLWLSS
Edited by MR FLWLSS
yeah i have one on my car and thats putting out 220kw on 12psi and i have hit 25psi in it a couple of times and its fine ;) some of my friends have got them to and they getting big power to. they may be cheap but just remember they are fairly old now t3/t4s but they still make good power and they are still made in the garrett factory at the end of the day. good luck with the sale mate.
thanks mate. well there you have it..... testimonial from someone ive never met...cheers mate thanks for the post
just goes to show what a good product this is, they are reliable and work great, are manufactured in the same factory as garret turbos but are half the price. so come on be quick $300 and its yours
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
