Good morning :thumbsup:
I am looking to do a major service on my car, as i will turning my daily into a track/street car.
I know what parts i will be putting into the car to help with the longevity of the engine, however, i need some advice on the following:
N1 Oil Pump - Can this be done easily while my mechanic does my timing belt and water pump? Also, what are the benefits of the N1 Oil pump over standard, and will the N1 fit my Rb25det Neo 6 ER34 motor?
N1 Water Pump - What is the benefit over a standard water pump, and will it be useful during street driving? I have heard it doesnt spin easy at low rpm and will cause overheating issues.
Any advice would be a big help for me.
Thank you kindly.
Chris
https://www.sau.com.au/forums/topic/222031-n1-oil-pump-n1-water-pump/
I think you can still do your oil pump with engine in but most people do it while the engine is out. If im not mistaken the N1 oil pump flows the same capacity but offers higher pressure over the stock pump.
And no the N1 water pump will not be 'useful' during street driving. There is nothing wrong with the standard water pump and an n1 unit does not offer any noticeable advantages on the street.
Not sure about the whole not spinning at low rpm... somehow i find that highly doubtful.
N1 water pump goes 2 more fins for nine in total, where as the normal one has has 7. The n1 water pump i dont think it is that much more then the normal one... maybe 50 or 70 bucks only.
So, if i was you, i would just get the N1 pump as its only extra ~ 70 bucks. However saying that,,, the normal water pump well work perfectly fine for street.. and if want to keep that 70 bucks for a tank of fuel instead! Then theres is no problem in that either~!
I'm running an N1 oil pump (got it from Sliding Performance) and a standard RB20 water pump.
From what I read, the N1 water pump is useless for street driving and was designed for sustained high revs (constantly 7000rpm+, i.e. around a racetrack) but it pretty shocking for low rpm street driving.
The N1 water pump causes cavitation during low RPM use, so is not a good thing for street driving. The N1 oil pump has a layered gearset which is prone to cracking on rev limit (cracked gearset means no oil flow). It also has increased flow/pressure which is a bad thing for RB engines due to their over supply of oil to the head. As for fitting, you wont be able to remove the oil pump without dropping the sump and to drop the sump its pretty much an engine out of car job. If i were you id leave both pumps stock (replace the w/pump with a stock item) and focus more on oil control mods. Theres not a great deal you can do with the engine in the car though. Id spend my money on a oil cooler if you dont already have one. Its a must for track work and will increase your oil capacity.
Deren
Edited by Godzilla32
  • Like 1
Deren
Deren,
Spoke to a mechanic today and he said exactly what you have. Thank you for the long write up and the advice.
You have all been great.
No more needed.
Thanks
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
