Hi Guys,
Have a pair near new Nexen 235/45/18 tyres, with 18 x 9" (+35 to 40 offset) Volk F1 Challenge rims
tyres are worth almost $400 alone, and if you search SAU for what Challenge rims normally fetch, you'll see that between the rims and the tyres these are cheap as.
Wheels have pretty bad gutter rash, but are machinable.
At this price, I'm pretty much giving the rims away anyway, so think of it as near new tread with some wheels thrown in....
Pick up Bris CBD only. Freight would be an extra $100.
WHYYYYY!?!?!?!
Why arn't these in 17!?!?!
I would of snapped them sooooo quickly!
Awesome price!
Just a quick question?..
Any idea on the weight of the rim?
oooooh.... let me see how much cash i have left after paying everything off tomorrow when i get paid!
any guarantee that neither wheel is buckled?
no 'guarantees' no - not because I am dodgy, but because I think you'd find anyone (other than a business selling a brand new item) will be loathe to 'guarantee' an item.
I can so far as to say that the rear wheel (which is not one of these two) was badly buckled, but the front wheels (which are these ones) appear to be nothing more than very noticeable gutter rash. very ugly - but tyres excellent, and wheels look to be fine. I have the option to import another set of rears from japan then machine the set as new, but frankly, this is too much hard work for such a little amount of cash.
I reckon they're great value for what they are - perhaps if you can figure out a way to check if they are buckled? I know they roll in a straight line.....
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
