Arc Induction Box - R33 Gtr - Unused, Still In Plastic!
I just spent a silly amount of time reading other forums' posts and watching "whats this noise" videos on Youtube. It *appears* to be the front diff having killed a pinion bearing or similar. Its almost definitely driveline, I haven't tested to see if the car makes the noise in N though but either way I think it's gonna be pricey. This is outside my area of comfort and expertise so I'll get my BMW guys on it. The bearings are attached to the hubs so are super easy to replace (at least in comparison to press in bearings) so I'll do them also.
Been a long time since I've played with those but I think C33 twin cam is the same as A31, any reason you're not using the engine loom you had before? Engine side is pretty much the same except the cir clip type plugs on A31/C33 so could swap plugs or electrics to suit.
1:13.559 My 'optimal' was 1:13.3-ish so I feel like I didn't leave much out there.
I had 295s on mine when I had a 34 and they didn't rub and that was with Nismo coilovers
Had a change of plan on my HICAS set up so have for sale a Midori Seibi canceller kit. Its not been used but has been test fitted Based in the UK but shipping to Australia is no problem £230 delivered to Australia (I think its about 450AUD :))
