hungry6...have heard good things about CNJ motorsport as well (although I didn't go there)...
I was quoted $550 - $650 for tuning -> that is always only for full throttle tune and everyday economy WILL be crap. But most tuners can fix that up with road tuning, albeit for another $50 - $100.
they will all say heaps of time 'plugging in numbers with fussy h/c' (about $150 of cost)
If you want PM me you details and I can do base map with you.
https://www.sau.com.au/forums/topic/22299-power-fc/#findComment-478678
It does...except the base maps (fuel and ignition) are quite far from idea (even more than the standard computer). E.g. at full load it runs as rich as 9.5:1...and you'll have difficulty getting more than 250km out of a tank.
Before taking it to a mechanic, you can fix most of the map so that the mechanic doesn't have to spend another 1.5 hrs changing the numbers to more ideal ones (which he will fine tune on a dyno anyway)...could save you some money
https://www.sau.com.au/forums/topic/22299-power-fc/#findComment-479857
Hahaha.. Good one Wayne.
He pays us nothing to spread the word. He knows how to deal with customers and he knows his skylines. That's all I need. Customer satisfaction and a mechanic that knows what he's doing.
Best business is word by mouth. He doesn't like to blow his own horn.
https://www.sau.com.au/forums/topic/22299-power-fc/#findComment-484652
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
