  • 3 weeks later...
  • Replies 82
Posted Images
Awesome colours, take it that's whit the new camera? would look a tad better if there wheels were blurred from spinning in the shot to give itmore of a feeling of movement .. but awesome none the less
Indeed the last two photos are from my 40d :blush: I love this camera!!
Perhaps with a bit of PP i could blur the rims, but i suck at PP and normally don't use it. Well ok i lied.. only for general editing!!
I noticed a big difference in quality from the 350d to the 40d - using the same lens too!!
I took well over 200 shots or so from dirft aus with the 40d and i didn't even have to edit any of them -- as in general things like contrast, sharpness etc.. I was so happy with them.. Will post up a few more :P
Edited by siddr20
^ this camera was well worth it :D
ooo but on the other hand a carbon bonnet :banana: SEXY!!! But i thought you were selling your car? lol
Heres a sequence of shots: (once again no editing at all)
Very nice!
Yeah .. it's up for sale..but my old bonnet got f**ked in a hail storm..and I couldnt find a normal black GTR bonnet..
but this bonnet has made me fall in love with the car again lol
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
