It was meant to be an R31 skyline club ONLY cruise, then posted one 1 other club that I am mates with. That was meant to be it. Person who posted it on here is on there and has taken it for something it's not and WILL be talked to and told in future to ask before spreading word. Obviously too late now to stop anyone coming, but maps are very limited, and if I don't know you, chances are you wont get one.
Edited by Dingus
Not at home to print maps. They are already printed and in the car waiting. Like I mentioned it was only meant for two car clubs, not as an open cruise. If I don't know who you are, I don't have maps spare to give you.
