Price Drops - Apexi Super Catalyzer Cat, Turbosmart Vee-port Bov $100, Jun Bl Muffler $175, Rb 3" Dump/front Pipe Combo, Injectors, Gab 8 Stage S14/s1
Selling the follow parts all located in Adelaide but will post at buyers expense. Contact me via SMS on 0404998591 or PM me. Not looking for SWAPS unless you have a FC Datalogit, Wideband O2 Sensor kit, Splitfire Coilpacks, Aftermarket Sidefeed injectors to suit SR/RB or a good aftermarket clutch setup to suit R33 GTS-t.
Apexi Super Catalyzer (Catalytic Converter) with Heat Shield in new condition only used for a couple of thousand kms removed from R34 GT-T but may fit other models. These are over $1200 in Oz even Nengun sells for $900+ delivered check out http://www.nengun.com/apexi/super-catalyzer . These are extremely high flowing catalytic converters with the best build quality I have ever seen check out the flanges with Apexi embossed! Price - $450
Turbosmart Type 2 Vee Port BOV complete with intercooler pipe & fitting this is the modern version not the old blue/orange version often seen. Price - $120 $100
JUN BL Muffler - this is the rare model like Marky used to run with the angle cut tip with JUN BL embossed into the side of the tip complete with ~60cm of pipe and flange! Cost $600 new used for the last 11 months sell for $250 $175!
Advance Headers Dump & Front Pipe Combo to suit RB came off RB25DET in R33. This is a top shelf item that gave excellent results and fitted like a dream! Used for 3 months paid $295 sell for $180
Link to company website http://www.advanceheaders.com.au/html/performance.html
Set of 6 x S15 Injectors removed from my RB25DET in perfect condition good for over $250rwkw - $350 Delivered
Brakes & Hubs etc
R33 Front Calipers complete with lines, pads, clips, shims, pins etc - Price $280
R34 Rear Calipers, Rotors, Pads, lines, Clips, Pins etc - SOLD PENDING PAYMENT
R33 GTS-T Brake Booster + Master Cylinder (Non ABS) - Price $100
R33 Front Hubs, Uprights etc - Price $200
GAB 8 Stage Damper Adjustable Shocks complete with lowered springs ready to bolt into your car. Shocks are in excellent condition, have been fully dissembled and checked, absolutely no leaks or knocks and can be adjusted from stock stiffness to rock hard in seconds. Perfect for those who want more control over there handling at the click of a dial. These will fit R33/S14/S15 although were removed from R33. Price $125
Brand New R33/R34 Front Cusco Camber Adjustable Upper Arms have just been trial fitted but never driven on as have changed plans on car so now up for sale - Price $450
Z32 AFM Plugs + ~30cm of loom ready to splice or wire into your loom to run Z32 AFM in excellent condition. Come complete with instructions on wiring into SR, CA & RB Powered Vehicles
Price - $30 Delivered or $20 pickup
Pair of R33 Front Seats in excellent condition. The drivers seat has a small tear in bolster nothing major. This is the comfy plush velour type model with the adjustable side bolster wings for more support through corners etc.
Price - $150
Freebies
Pair R33 Front Castor Rod Chassis Mounts
Pair S13 Rear 4 Stud Hubs
Location - Adelaide
Contact - SMS 0404998591 or PM
Pics of all bits will be up tommorow
Edited by nigelswazi
interested in front/dump, shocks and castor Rod mounts...
Are you able to send all of these items to Melbourne?
And do you have pics of shocks on car?? Ride height...
Dump Pipe now confirmed SOLD
Also have 6 x 650cc Side Feed Injectors for sale red in colour believe they are Blitz - $550 Delivered
Shocks and Castor Rod Mounts still available PM sent
Many have requested pics of the Apexi Super Catalyzer and Turbosmart Vee Port BOV Pics are below as I forgot to add and can't edit post
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
