Sorry it's prob so easy for you guys but I don't know Nissans very well.
I would like to know if an RB24 (I'm Oz in Asia atm) long engine is basically directly interchangable with an Ozzie RB30. I am a mechanic and have done conversions before so little details don't bother me. Also what would be the guess of what 5 speed box would be behind it compared to the Oz version? If different box what about mounts and bulk?
My idea is I will be here for a while and would like to build a club racer here in my spare time, use the dead RB24 engine I found as a dummy then ship the rolling chassis back to Oz when I return and drop an RB 30 engine, hopefully, straight in.
Thanks Guys, appreciate your time.
Mark :-)
https://www.sau.com.au/forums/topic/224921-rb-24-rb-30/
gearbox should bolt straight up, i believe the smaller RB motors and the RB30E use a ~9.5" flywheel and clutch to suit, it was the RB30ET that had the 10" and skyline boxes wouldnt clear the clutch properly
i dont know if your asking what box to use or if yours will fit, but im gonna guess you've got an RB20 box which will fail quite early on if driven hard. i dont see any point in just swapping to an RB30 bottom end, and the RB20 head doesnt really flow all that much more than the RB30's SOHC, you'd probly be better off just bolting in the RB30 providing you can get the loom adn ecu, unless the laws over there wont let you
Edited by VB-
https://www.sau.com.au/forums/topic/224921-rb-24-rb-30/#findComment-3962298
Well RB24, is a RB20 stroked.
RB30/RB20 interchangeable without much effort.
Actually, it's the other way around. The factory Nissan RB24S (supplied in malaysia and a few other contries) has the stroke of an RB20 and the bore of an RB25, so it's more likely a short stroke RB25.
I would guess being a more economical engine and having less power than an RB20DE it would probably utilise the RB20 gearbox.
https://www.sau.com.au/forums/topic/224921-rb-24-rb-30/#findComment-3962357
When most people say RB24, they are usually referring to a modified RB20. But even bored out to 82mm (from standard 78mm) and using RB26 crank, you only end up with 2.3litres. All of the other RB engines have a bore of 86mm, so using the 20crank you end up with 2.4litres. Then the 25, 26 and 30 engines are just larger stroked and different heads.
https://www.sau.com.au/forums/topic/224921-rb-24-rb-30/#findComment-3963394
I can't speak to how accurate it is, but I found this info on the rb24S on wiki a while ago
RB24S
This is a relatively unknown engine, as it was not produced for the Japanese domestic market. These were fitted to some left hand drive Nissan Cefiros exported from Japan new. Mechanically it is made from an RB30E head, RB25DE/DET block and RB20DE/DET crank with 34 mm height pistons. This engine used carburretors instead of the Nissan ECCS fuel injection system. It is able to rev harder than the RB25DE/DET (as it has the same stroke as the RB20DE/DET) as well as being almost the same displacement as the RB25DE/DET. A common modification is to fit a twin cam head from other RB series motors while retaining the carburreted set-up. The standard single cam form produced 141 PS @ 5000 rpm and 20.1 kgf·m (197 N·m) of torque @ 4400 rpm.
https://www.sau.com.au/forums/topic/224921-rb-24-rb-30/#findComment-3963526
Yeah, we kind of already discussed that. That is what a true RB24 is.
Modifying an RB20 block using different stoke and bore combination results in volumes between 2.1 and 2.3 litres.
...The factory Nissan RB24S (supplied in malaysia and a few other contries) has the stroke of an RB20 and the bore of an RB25
https://www.sau.com.au/forums/topic/224921-rb-24-rb-30/#findComment-3965773
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
