Sorry it's prob so easy for you guys but I don't know Nissans very well.
I would like to know if an RB24 (I'm Oz in Asia atm) long engine is basically directly interchangable with an Ozzie RB30. I am a mechanic and have done conversions before so little details don't bother me. Also what would be the guess of what 5 speed box would be behind it compared to the Oz version? If different box what about mounts and bulk?
My idea is I will be here for a while and would like to build a club racer here in my spare time, use the dead RB24 engine I found as a dummy then ship the rolling chassis back to Oz when I return and drop an RB 30 engine, hopefully, straight in.
Thanks Guys, appreciate your time.
Mark :-)
https://www.sau.com.au/forums/topic/224921-rb-24-rb-30/
gearbox should bolt straight up, i believe the smaller RB motors and the RB30E use a ~9.5" flywheel and clutch to suit, it was the RB30ET that had the 10" and skyline boxes wouldnt clear the clutch properly
i dont know if your asking what box to use or if yours will fit, but im gonna guess you've got an RB20 box which will fail quite early on if driven hard. i dont see any point in just swapping to an RB30 bottom end, and the RB20 head doesnt really flow all that much more than the RB30's SOHC, you'd probly be better off just bolting in the RB30 providing you can get the loom adn ecu, unless the laws over there wont let you
Edited by VB-
https://www.sau.com.au/forums/topic/224921-rb-24-rb-30/#findComment-3962298
Well RB24, is a RB20 stroked.
RB30/RB20 interchangeable without much effort.
Actually, it's the other way around. The factory Nissan RB24S (supplied in malaysia and a few other contries) has the stroke of an RB20 and the bore of an RB25, so it's more likely a short stroke RB25.
I would guess being a more economical engine and having less power than an RB20DE it would probably utilise the RB20 gearbox.
https://www.sau.com.au/forums/topic/224921-rb-24-rb-30/#findComment-3962357
When most people say RB24, they are usually referring to a modified RB20. But even bored out to 82mm (from standard 78mm) and using RB26 crank, you only end up with 2.3litres. All of the other RB engines have a bore of 86mm, so using the 20crank you end up with 2.4litres. Then the 25, 26 and 30 engines are just larger stroked and different heads.
https://www.sau.com.au/forums/topic/224921-rb-24-rb-30/#findComment-3963394
I can't speak to how accurate it is, but I found this info on the rb24S on wiki a while ago
RB24S
This is a relatively unknown engine, as it was not produced for the Japanese domestic market. These were fitted to some left hand drive Nissan Cefiros exported from Japan new. Mechanically it is made from an RB30E head, RB25DE/DET block and RB20DE/DET crank with 34 mm height pistons. This engine used carburretors instead of the Nissan ECCS fuel injection system. It is able to rev harder than the RB25DE/DET (as it has the same stroke as the RB20DE/DET) as well as being almost the same displacement as the RB25DE/DET. A common modification is to fit a twin cam head from other RB series motors while retaining the carburreted set-up. The standard single cam form produced 141 PS @ 5000 rpm and 20.1 kgf·m (197 N·m) of torque @ 4400 rpm.
https://www.sau.com.au/forums/topic/224921-rb-24-rb-30/#findComment-3963526
Yeah, we kind of already discussed that. That is what a true RB24 is.
Modifying an RB20 block using different stoke and bore combination results in volumes between 2.1 and 2.3 litres.
...The factory Nissan RB24S (supplied in malaysia and a few other contries) has the stroke of an RB20 and the bore of an RB25
https://www.sau.com.au/forums/topic/224921-rb-24-rb-30/#findComment-3965773
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
