http://www.pgasa.com/
professional golfers association of south africa
no, seriously, Pulsar Group of Australia - South Australia
if we had a dollar for everytime that joke.... :P:laugh:
oooooo k.. pulsar something australia australia.. got redundancy?
well i mean they drive pulsars.. so yeah haha enough said :(
ha ha Steve, I'll take your s13 on in my pulsar, at Mallala of course :P
  • Replies 137
Posted Images
if we had a dollar for everytime that joke.... :P:O
ha ha Steve, I'll take your s13 on in my pulsar, at Mallala of course ;)
i just might u know. car is very close to being completed. will be interesting to see how it does on the track.
Anyone else keen to enter their car in this on Saturday?? It's only $40 to enter and find out how much power your car is making :wave:
I will be there and depending on my mood
the car just might get a dyno run
just suck it up and stick it on krishy :wave: i've gone a few kw's up, with the hiflow you might get a few back on me!
i will if i can get my car serviced before then
last year from memory there was no other SAU representative and the only other import skyline was Jack Baker tyres who was a sponsor
Well done for representing SAU last year Steve........there was a bigger SAU representation this year with Destroy, Jenkies, Krishy, Luke ENR34 and me last minute (after alot of arm twisting), lol.
Here are the 2007 & 2008 results:
2008 Results
PGA_Dyno_Day_2007_Results.doc
sorry i couldnt attend, work commitments. 1 kw... baahahahahah awesome stuff. should have got them to run mine first thing in the morning when it was cooler ;) nice work pete!! a big thanks to chad for whatching over my baby! so much appreciated!! luke.. glad you could make it :D
hopefully have the line back on monday then i can take her for a graceful drive down to victor harbor.. suss it all out!!
cheers to all involved!
yeah sorry about that bud, I think we both ran approx 16psi boost but with my ball bearing/cooled turbos I had alot more left in the tank. I told Brett to run them on par with each other in RWD mode......I didn't think they'd be so close though.
Your car has become a bit of a beast now Mark and was running very crisp with no smoke belting out the back, unlike mine that bellowed out black smoke............got to pull some fuel out of it but I'll leave it until the turbo swap happens.
Anyway, congrats on the trophy & prize bud and be careful you don't go losing that license again with all that power on tap now :D .
Dang, spewing i missed this, had to pull out due to cricket and knock issues. I wouldve placed about 4th in RWD too :thumbsup: Well done Pete and Jenks, a couple of cars getting faster and faster, making it harder and more expensive for the rest of us to catch up :D
Dang, spewing i missed this, had to pull out due to cricket and knock issues. I wouldve placed about 4th in RWD too :P Well done Pete and Jenks, a couple of cars getting faster and faster, making it harder and more expensive for the rest of us to catch up :)
ohh it was a freaking awesome day
the dyno room was air conditioned so i dont think that the weather really affected any of those results
hahah damo i made 179rwkw on 7.8psi of boost with a 15sec ramp rate
could have made more if i had ran more boost
and pete your smoke machine sounds insane lol
it was a good turnout and good to see/hear SAU taking care of high power lol
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
