Hey Guys,
Am needing cash for Skyline Nationals so selling a few bits and pieces.
Wheels:
i have for sale a set of Japanese 'Zeit' 17x9.5 17x8.5 Off 35/40 Rims,
The front left rim has a crack through the spoke so i have purchased new wheels and no longer require these.
Apart from the crack the wheels are in great condition and look fantastic.
The package is $470, the front tyres include rubber (70-60% left..)
Front Bar:
I am selling my old front bar which is shown in picture 19032008052
I am not sure of the details of this bar which is in used condtion and just requires paint.
I'm chasing $200 for this item.
10" Sub and Amp package:
Im looking to sell my 10" kicker sub in JVC Box with Schneider Amp (2 channel 500Watt) and wiring
Im after $150 for the package.
Pick-up is desired for these items,
Please dont hesitate to contact me on 0412327306 or flick an email to [email protected]
Thanks
-Ryan
https://www.sau.com.au/forums/topic/225484-17-zeit-wheels-more/
