Make:Mx5 Roadstar
Model:1990
Milage:104500k's
Transmission:manual
Colour:silver
Complied?yep
RWC supplied?can be supplied
Currently registered?no
Price:$10000 ono very neg
Contact:MESSAGE 0431117368 as i work all different times of the day and night or just pm me
Comments / Modifications:The only reason i wont to sell or swap it is casue i have lost my licence for 2 years na really want to do up a turbo car. Well it is a mx5 roadstar with 104500k's, it is a manual, new tyres all round, new tailsharf, has a stereo in it, soft top(chicks dig them lol) there is 1 dint on the fuel cap cant even notice it i was there for a hour looking for dints and that is the only one i found, hsa no rego but will come with a rwc, may come with a setof 17inch mags all depends if i get them or not and it is also cheap on fuel gets 500k's easy for 45bucks i think that is wicked, well that is about everything i can think of just pm me for question. It is also on boost if you want to cheak it out on there http://www.boostcruising.com/forums/index....c=310412&hl=
Images
https://www.sau.com.au/forums/topic/225675-mx5/
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
