I have decided that i wont keep the car for that much longer. Therefore the following bits and pieces are for sale.
Brand new unused Z32 afm with wiring loom - $275 delivered anywhere in australia
PWR auto transmission cooler measuring 280mm x 200mm, with approx 600mm oil entry and exit rubber lines - $75 with postage
Sard 550cc side feed injectors in R33 series 2 fuel rail, selling it for what i paid it em. Bought em off an SAUQLD member, they were used in his car for approx 5000klms before he went with an 26 plenum conversion - $450 plus postage
What you see in the pictures is what is included, nothing else
Greddy Emanage Ultimate with universal 14 pin harness adaptor and R33 GTST plug n play adaptor. CD software included, never been used, willing to seperate, make me an offer and we'll work it out from there - $750 for the lot delivered australia wide
Contact via pm or call/txt me on 0410 594 978. All items are located in Cairns.
Have the auto tranny cooler left and the emu. Tranny cooler previously sold pending payment, buyer pulled out, back up for sale
Tranny cooler 75 + postage
EMU + R33 adaptor + 14 pin universal harness for 700 delivered aus wide
Chris
Emanage Ultimate back up for sale. Getting dicked around.
$700 delivered, with the R33 adaptor and universal harness.
PWR tranny cooler $90 posted aussie wide.
Also found a HICAS bar and rear pineapple bushes. 100 bucks for both posted.
Chris
nice price for the e-manage! can I ask where you got the r33 plug n play adapter from? I assume you don't want to sell that separately? pm if you like
Got the adaptor from overseas, along with a fair few other things, but then decided to sell the car instead, so all the bits are going. Would prefer to sell together, but make me an offer on the adaptor.
Will do $650 for the Emanage Ultimate +R33 adaptor + 14 pin universal harness, posted to ya door.
Getting keen to sell this gear gents and ladies!
Chris
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
