  • Replies 48
i think the psi's were around $1200 for a set dont quote me, and the supertech's are USD$459 (they come with their own titanium retainers)
Depends how much ur spending/want to spend on the head, with the dual springs you'll need to get a custom inner seat made for the inner spring
  • 1 month later...
Hi, I am just seeking some clarification on some of the info here about cam choices.
I am about to send my spare rb26 head out for porting and reconditioning etc. I will also be asking them to clearance the cam tunnel to accept bigger cams, and have budgeted to upgrade valve springs as per the comments on here. I am building a separate long motor with a 3.0 (realistically 3.1) bottom end to swap into my r32. Will be getting a fully balanced, forged etc bottom end from a shop and assembling myself.
In terms of the use, it will NOT be a daily driver, so off-boost response is not as crucial - however, I DO want my vaccuum assist to work from idle (ie brakes etc) w/o having a resevoir.
I have read on here that the 3.1 bottom end will "soak up" big cams, which intutiviely makes some sense - at the moment I am looking at either 272 or 280 duration, which provides lift in the region of 10-10.5 mm.
Is this ridiculous, unusable power for a 3.1? I would like to have boost on or before
4, 000 rpm. There will be inherent limits on revving out a big stroker motor. I also want working vacuum assist. As always, all advice or recommendations greatly appreciated.
i had a similar chat with dirtgarage about losing vacuum & braking power off-boost, could be very dangerous at times for a street car
im sure he can advise with his words of wisdom
...i just realised this is in the rb30 conversion group, he calls them 'forklift motors'...not much of a fan but i am :P
Edited by Marko R1
thanks, will wait any further feedback on loss of vaccuum.
My other queries relate to potential issues with valve-to-piston clearance using high-lift cams. Does anyone know at what lift the valves are at risk of hitting the pistons? I need to consider whether I want to raise the static compression ratio to compensate
for the lack of dynamic compression created by the big duration. Has anyone had any experience with using pistons with valve reliefs?
Finally, I am looking at having my porting work done by lewis engines in adelaide (very few choices in Canberra). Has anyone had any experience with them? feel free to shoot me a PM on that point.
perform a search on proengines, greg is very well priced with quick turnaround and everything he does is onsite and by 1 person so no middleman involved. has built way too many rb's and infact just about finished my 26/30.
ive seen my head porting which looks fantastic and is supplying flow bench testing with before v's after results...can i ask for more? others such as scooby have used the same workshop.
talk to greg about your setup, he can answer your q's mate :)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
