Whats a ceffy cage worth? Might get rid of it once its here to help pay for my brake upgrade an complance. Also anyone got any idea on the power it could make? rb25,kkk-26 turbo(or someshit), 8 injectors,aftermarket comp,metal headgasket,intercooler thinks thats it! Rotas are so more simple.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
