these parts left, priced to sell........
Tailgate,lights,wing $300 complete
left side doors including interior trim $150ea
box $450
engine minus turbo $1400
seats $200
seatbelts complete set, $80
right side electric mirror $50
diff and rear craddle $450
speedo cluster $100
dash $100
Do u have the drivers side weather shield above the drivers and passenger window. Will pay top dollar if u have? and also the grey carpet panels attached to the back of the rear seats. I want to put an amp in but dont want to damage mine until i can get another set.
  • Replies 81
Sideskirts are they Dayz?
If so I will take them if still available.
Also need interior A pillar moulds...
Edited by inmate
i have the carpet panels but dont have the drivers weather shield
how much for the panels to be posted to melbourne and also would u seperate the back boot door. i am after the carpet panel in the boot as i want to put speakers in. If this is available how much is it going to cost to get all of it to me?
Travelling through C-Town tomorrow.
Would like to purchase the sideskirts.
Can you PM me your number so I can give you a call when I am in the area?
Just wondering if there still are some parts left.....
Interested in the sideskirts (how much is left of the second one...)
Would like the rear wing as well if you would separate it since the shipping probably would be expensive to Sweden otherwise!
Would you consider shipping over here...
Chears!
  • 3 months later...
sorry had lost my password
i have the following left
both left doors, 100ea
right passanger door, 100
tailgate dayz tune wing and tail lights 300
diff and shafts-rear 350
front left guard, 50
boot pannel 50
right side mirror 50
  • 4 weeks later...
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
