Hi Everyone,
I've just been doing my winter clean-out of the garage and I stumbled upon a few parts that might be of use to somebody :(
1) Genuine S14 Recaro seat rail (drivers side) with slightly higher mounts that were fabricated in-shop. The previous owner raised the rail slightly and I am a little tall for it, which is why I removed it otherwise it's in great condition. This rail would suit a driver around 160cm - 170cm who uses a Recaro SR3 or equivalent Bride seat. $150
2) I purchased a set of near new S15 coil packs last year and never ended up using them, they are in great condition. $200
3) TurboXS Type-H BOV with R33 cold pipe adapter plate, signal tube and original bung for OEM plumb-back included. This is a brilliant BOV that safely holds a heap of pressure without leakage and it's practically brand new! $180
If anyone has any queries about these items please feel free to drop me a PM or call me on 0438903064, more than happy to answer any questions!
Cheers people :)
https://www.sau.com.au/forums/topic/226866-s14-s15-and-r33-bits/
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
